09-22-2008, 12:47 PM
Alodining long parts...
I'm about to clean and alodine the aft wing spars. What's your technique for cleaning and alodining parts that won't fit in a container?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
09-22-2008, 12:51 PM
Senior Curmudgeon
I have used PVC pipe, cap one end and fill with Alodyne. For longer parts, cap both ends, cut lengthwise in the band saw to make a trough. Build a cradle to hols the trough and go for it.
You could also make a trough from 2x4s and visqueen or such.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
09-22-2008, 02:13 PM
Trough
A length of household gutter with end caps works.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
09-22-2008, 02:44 PM
I just used one of the crates that Van's used and lined lined it with plastic. Granted, there are several nice long, but skinny crates that Van ships for the RV-10 that may not be used with the other models.
09-22-2008, 03:32 PM
Bear in mind the part does not have to soak to the gills in the solution. It may be wiped on with a sponge or cloth that has been saturated in the solution. Also it may be sprayed.The main thing is to not let it dry before being rinsed.
A single piece of plastic could contain all that might run off.
Randy Hooper
09-22-2008, 03:53 PM
If you've got access to one of those FoodSaver vacuum bag devices, buy a roll of the bagging material, seal one end, and you've got a nice long bag you can put long parts in. Pour in the alodine, roll up the open end a few times, put a clothespin on it and then let it sit for a few minutes. Open the end and drain it back into your container.
PJ Seipel
RV-10 #40032
09-22-2008, 05:38 PM
Spraying with a...
Randy Hooper
...household plant type mister bottle works well.
Just make sure to get the cheap one with the plastic works.
Internal metal parts would probably contaminate the alodine, and would certainly get etched by the acid...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
09-22-2008, 09:57 PM
FoodSaver Bags
Ditto on the Food Saver Bags....Works Great!!
09-23-2008, 07:34 AM
I'm glad I gave up on the Alodine, way to messy for me!
