Yep ... to the inside
Paul,
I moved the panel support ribs to the inside for exactly the reasons you note. I moved them inside sufficiently to allow centering a GRT display on both the L and R sides. Not too hard to do, but custom fabrication is always slow work compared to the usual Vans assembly.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
