Old 09-20-2008, 03:39 PM
alcladrv alcladrv is offline
Default Fuel cap maintenance
I recently replaced both o-rings on each fuel cap after 350 hrs. in 3 years in my -7A. Neither cap fully seals against the water when it sits out in the rain any better than before I changed the o-rings. The left side has been increasingly hard to push down the "ears" on the cap to lock it. I adjusted it to where it works a little easier.
Should I use some kind of lube on the fuel caps and o-rings? What is a good guideline to use to adjust the caps as well as possible?
Mike
Old 09-20-2008, 05:20 PM
Mel's Avatar
Mel Mel is offline
Default Yes!
Lube the "O" rings regularly. Almost any lubricant will do. I use Lubriplate. I clean and re-lube them during condition inspection each year.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-20-2008, 05:38 PM
Thanks, Mel
Old 10-02-2008, 09:44 PM
billnaz's Avatar
billnaz billnaz is offline
Default metal vs plastic parts
The caps on my old 6A had plastic components that failed after a years use. When I ordered replacements the new ones were metal. It's the square gasket that the cam of the latch pivots on as you close the cap. If you have older caps they may have the plastic part. You can get the name of the manufacturer from vans and order the parts direct (I'm not near the plane to look it up). New parts work great, good seal and function.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 10-03-2008, 01:15 AM
gasman gasman is offline
Mike
GET A TUBE OF EZ TURN FROM SPRUCE..... http://www.aircraftspruce.com/catalo...ezturnlube.php A tube will last you a lifetime. After you lube the "O" ring then set the nut so you can install and remove the cap with a little amount of resistance.
EZ TURN will not wash off with gas and it will allow the o ring to slide up the taper of the cap as you flip the latch. YOU WILL LOVE IT.....
Old 10-03-2008, 06:29 AM
AlexPeterson's Avatar
Unless you try to use them when cold.... if the temps are in the 30F and below, it gets difficult to remove the caps. Down around 10F and I had to abort fueling until getting it in a warm hangar. No way to get them off. I now use Tri-Flow around once a year and it works great, even when cold.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 10-03-2008, 08:31 AM
McFly's Avatar
McFly McFly is offline
Just in case you haven?t tried this: Put some light oil (LPS ,10W40, 3in1,?) around the shaft where the ears attach. It will work wonders. Good luck.
Hugh
Northern California
RV-7 Flying
Old 10-03-2008, 04:08 PM
Griff's Avatar
Griff Griff is offline
Just before you reinstall the cap, dip your finger in the fuel and drip some on the cam section.
It makes for a decent lubricant, but times-a-wasting because it will evaporate quickly.
Randy Griffin
RV-8
N925RG
Vancouver, Wa.
Old 09-13-2012, 08:26 AM
Bart Bart is offline
Default Fuel Cap Servicing
Anyone got a step by step for servicing the fuel caps. Mine get tougher to open as they age.
Old 09-13-2012, 08:53 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Gently remove the large "O" ring from the outside of the cap.
Use a Q tip to spread a thin layer of fuel lube in the "V" groove where the "O" ring lives.
Reinstall the "O" ring.
Use the Q tip to apply a thin layer of fuel lube on the exterior of the "O" ring.
Done.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
