Old 09-27-2005, 10:38 PM
Jamie's Avatar
Jamie Jamie is offline
Default Jetblue Incident Photos - Not RV Related
A friend of mine who claims to have some connections got some close-up photos of the recent Jetblue incident. I found it interesting that the tires were still attached. What are the chances of Van's hiring someone that had a part in the design of the nose gear on that sucker? ;-)
The forums limit the number of pictures allowed in a post, so you can go here for more pictures (and higher resolution).
Old 09-28-2005, 12:31 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Jetblue photos
Very interesting! Thanks for posting them.
Mickey Coggins
http://rv8.ch
"Hello, world!"
arffguy arffguy is offline
Default Wrong airplane??
Something's not jiving between the recent story and these photos. The recent JetBlue incident involved N536JB "Canyon Blue" not N503JB "Bluebird." Each of JetBlue's airplane has "blue" in its name, you know. N503JB was JetBlue's first A320 delivered by the way. I know this nosegear problem has happened before but has it happened to JetBlue twice??
Still, they are cool photos though.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 09-28-2005, 05:28 AM
Jamie's Avatar
Mikey:
I really can't verify the authenticity of these photos...so what you say may very well be true. It's interesting either way -- the photos are of the recent incident or *another* incident with a similar problem.
I just found an article on Findlaw (and other places) about 7 other incidents involving Airbus nose gears, including one incident in November 2002 where the pilot had to make a landing at JFK just like the one we saw in California. The article is here.
The picture taken from a distance shows the aircraft sitting well off the centerline. If I remember correctly, the captain put the aircraft exactly on the centerline. Also, the person standing there is wearing what appears to be a heavy winter coat, which tells me this could be the JFK incident.
BTW: Here are the two other pictures I couldn't get in my original post:
Old 09-28-2005, 05:56 AM
mlw450802's Avatar
mlw450802 mlw450802 is offline
I guess it's possible for two times for Jet Blue but it's certainly bad luck, if true.
Also, I'm not sure the weather in LA requires winter coats yet and I don't remember the yellow stripe down the center of the runway either (key words: don't remember)
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 09-28-2005, 06:32 AM
jclark jclark is offline
ANd another thing that struck me ... I thought the tires burned quite a bit on the LA landing.
Thanks for the photos in any case.
James
Old 09-28-2005, 06:44 AM
Air UPSer Air UPSer is offline
Those are all photos from the JFK landing several years ago.
Brad
Old 09-28-2005, 06:52 AM
Scott Will's Avatar
Scott Will Scott Will is offline
you're right, they are from the JFK incident. Another way to tell the pics aren't from LAX - check out the guy in the winter coat!
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 09-28-2005, 07:08 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Actually three give aways that it's not last weeks LAX incident:
1) winter coat (already mentioned by Mike and Scott)
2) the LAX bird came to a stop at the end of and in the middle of a runway center line stripe. This JFK bird is two feet or so left of center white stripe.
3) the most obvious thing to me is the water (NY bay or something) in the background.
RV-7 Flying since 2004
1,100 hrs+
Old 09-28-2005, 11:45 AM
dwilson dwilson is offline
Default No N503JB in FAA accident files!
Just searched the FAA accident/incident files and found no refference to N503JB as far back as 1980. Wonder what these pictures are reall of????
Duane Wilson
