09-19-2008, 12:10 PM
deburr canopy edge
Hi,
I tried to smooth the edge of my canopy with the 3m scotchbrite drum mounted on the die grinder.
Do you think is a good idea or it's better to use sand paper ?
thanx in advance
09-19-2008, 02:23 PM
Scraper
Hi Luca,
I didn't try the scotchbrite wheel, but I did use a small sanding drum in my die grinder. I thought it turned awfully fast and had a tendency to "melt" the plexi if not teasing the trigger. It also didn't really leave a smooth finish, but perhaps the scotchbrite wheel does? Also, because it is round, it makes it a little harder to get a perfect edge without ripples (because the roundness wants to sand a round "divot" in the edge if you're not careful and constantly moving it along).
What I found best was to carefully knock down any bigger ridges with the sanding drum, and then use the scraper I got from Avery to smooth and round the edges. That left it pretty much done. If you want an amazing finish, wet a strip of 400 grit sandpaper and sand away like a shoeshine boy on the edge and you'll be pretty much able to "see through" the edge. It doesn't take much after the scraper.
Here is Avery's scraper...
http://www.averytools.com/p-410-plex...e-scraper.aspx
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
09-19-2008, 03:05 PM
canopy edge
Originally Posted by java
Hi Luca,
Ditto on the Avery Scraper excellent tool-just don't dig it into the sides, keep it perpendicular to the canopy edge. I also used a palm sander 4x4 square pad with 100 grit and 320 grit to get alot of material off at a time. Let the sandpaper do the work, don't be rough and securely hold the canopy with your free hand.
Mike H 9A/8A
09-19-2008, 04:09 PM
has anyone tried a vixen file? It might be too aggressive, but might be worth trying on a piece of scrap!
Ian
09-19-2008, 04:13 PM
Super Moderator
I suggest getting the scraper from Avery. It's quick, easy and does a great job.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
09-19-2008, 08:14 PM
Yes....
...a short piece of vixen file (about 3 to 4 inches long) with a handle RTV'd to one side makes a good edge cutter.
I used one to clean up the edges after a 2 inch grinding wheel with a medium/coarse grit took it down to the correct line.
Just press lightly...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
09-20-2008, 11:09 AM
or maybe a microplane or something... lots of possibilities worth experimenting with.
I don't have a canopy yet so I can't try them myself
Ian
09-20-2008, 11:37 AM
The plexi cleans up very quick... use 80 grit to shape and 320 grit to polish. In 30 minutes you're done.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
09-28-2008, 07:05 AM
Try the scraper on the first pass. Quick and easy and works well. Then buy something like a cheap 5" electric orbital sander. I got a 5" at HF for $39. Start with something like 180 grit and it will be perfect. Not agressive, no stress, no heat, and it comes out very smooth. You will find a lot of uses for the sander when you go to final fit the fairings.
Bill S
7a finishing
