Old 09-18-2008, 10:18 PM
danielhv's Avatar
danielhv danielhv is offline
Default Torque Wrench & Extension...
How will my torque settings be affected when using a 3" extension? Enough to worry about? Its a click style wrench btw.
-Daniel
Old 09-18-2008, 10:19 PM
tmbg's Avatar
tmbg tmbg is offline
Hold the head of the wrench in your free hand and ensure that you're not side-loading the extension at all, and there's no effect on torque values.
Ian
Old 09-18-2008, 10:23 PM
szicree szicree is offline
That depends what type of extension we're talking about. There are the type that everyone has that extend the drive of the ratchet so that you can reach into a hole (like changing spark plugs). This type will not affect torque settings. Then there are the type that actually look kinda like a box-end wrench. The ratchet drive goes in one end of the wrench and the other end of the wrench goes on the fastener. This second type will definitely change the torque and must be compensated for.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 09-18-2008, 10:25 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
-Daniel
Nadda... most of the time, unless you're dealing with big stuff will an extension harm you with torque values. We are dealing in small values most of the time.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 09-19-2008, 05:52 AM
deene deene is offline
Actually, it always affects the results...however, if the extension length is a very small percentage of the torque wrench length, the result MIGHT be negligible.
The actual torque versus indicated torque is higher by a ratio of the length of the extension divided by the torque wrench length. Thus a 1 inch extension (crowfoot) on a 10 inch wrench will give an actual torque 10% higher than indicated. But a 3 inch extension will give you 30% higher torque!!!!
If the math makes your head hurt, use the following online calculator:
http://www.belknaptools.com/extcalc.asp
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 09-19-2008, 05:57 AM
Geico266's Avatar
Geico266 Geico266 is offline
Wow! That is a cool torque calculator. That baby is going in my favorites.
Thanks Deene!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-19-2008, 08:19 AM
tmbg's Avatar
I imagine he's talking about a socket extension, not a handle extension or crows foot. We're discussing extensions along different axes.
Ian
