09-18-2008, 12:20 PM
Originally Posted by danielhv
I see, I'll give that a try too, its just hard enough trying to clamp that little piece down as it is and still leave room for the cutter! (2" x 1.25" tiedown spacer and cutting a 1" hole)
1. your saving .2 grams
2. i would cut the hole before i cut the stock down.. makes it easier to handle. or use a drill press vise.
William Weesner/ still kicking.
09-18-2008, 12:21 PM
Senior Curmudgeon
You can mount the 2x4 to the table from underneath with a few wood screws, then clamp to it.
Just keep all the parts firmly positioned.
The fly cutter exerts an asymmetrical force as it is spinning, and that is where the problem lies.
A drill bit has two cutting edges, which balance the force of each other.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
09-18-2008, 12:24 PM
bit orientation
If you want straight sided holes, the point of the tool must be to the outside. If you want cylinders with straight sides, set the tool with the point toward center.
I would use something other than a flycutter to cut lightning holes in the VS spar. Sears type fly cutters are best used for thin sheet stock.
Steve
09-18-2008, 12:41 PM
Originally Posted by Mike S
Take another look at this photo from post 5. Thanks Brian.
The entire stackup is clamped to the drill press table.
If you are only clamping to a piece of 2x4 as stated above, then things can still move around, and that aint good
If you can clamp the work to the table with the work up against the drill press' vertical column, that will help your physical well-being when the cutter stalls in the work!
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
09-18-2008, 01:07 PM
Steve
I spotted this little gadget at Chip Ganassi's racing shop. I think it punches holes from 1/8 inch to around two and a quarter inches, but it might be a bit more expensive than a fly cutter!
Ron Leach
Cincinnati
.....Bob Seger
09-18-2008, 01:41 PM
Cut my hole pannel out with one.
I had excellent luck with the same from ACS.
Slow speed, a little oil, wood board underneath, bit oriented properly and make sure it is sharp.
If you sharpen, don't burn the bit. I did sharpen periodically.
You might be putting too much force and not letting the bit cut at its own pace.
Webb Willmott
Jackson, MS
N32WW
09-18-2008, 01:54 PM
prices starting at $11,788 !!!!!
Jonathan Hines
Charlotte, NC
09-18-2008, 02:16 PM
GROUP BUY!!!!!
Oops, shipping it around might be a problem......
Ron Leach
Cincinnati
.....Bob Seger
09-18-2008, 02:29 PM
I don't know if it makes any difference but I used a unibit and just drilled a 3/4" hole there.
Tom Joyner/ F70 (French Valley, CA)
09-18-2008, 03:38 PM
1" Bi-metal Hole Saw
I used a 1" hole saw with some cutting fluid...fewer problems with rpm. Clamped the long piece of stock in the vice and used the drill press.
I use the fly cutter on sheetmetal (like tank end ribs) with no problem.
For hole saw, see:
http://www.homedepot.com/webapp/wcs/...ctId=100495351
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
