Old 09-16-2008, 12:24 PM
bkc3921 bkc3921 is offline
Default Whelen Power Supply Mounting
Most people mount the strobe power supply aft of the baggage compartment or in the aft floorboard...Is there a problem with mounting it in the sub-panel (the area under the top forward skin of the 7a)..??? The instructions say you only need to keep it away from the ADF antenna, if you have one, but I just wonder if there is a problem with the supply close to the radios..Don't want to run into a noise problem..but would like to mount it upfront if possible..Any RMI or EMI guru's care to comment? Thanks in advance...
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
RV-12is EMP in progress!..Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
Old 09-16-2008, 12:36 PM
Brantel's Avatar
Brantel Brantel is offline
I think that is what Rudi did. You might PM him to see how he likes it now that he is flying....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-16-2008, 02:25 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Strobe power supply aft of main spar
If you put the PS aft of main spar (under the baggage floor for example) you don't have to run all those strobe cables through the main spar.... just the power/ground wire. Also, an electrical/avionics engineer told me the PS base should be electrically isolated from the fuselage and ground it with a wire to your star ground point. That will help keep the airframe from "pulsing"... keeping the PS charging RF noise down.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
