Old 09-14-2008, 08:20 PM
danielhv's Avatar
danielhv danielhv is offline
Default Messed up my AEX Tie Down...
So Im looking at the plans, which say in one spot to drill a hole with some edge measurments... then right underneath it, it says : 8x 3/16... So I'm thinking "Ok, so I drill 4 of these holes on each tiedown w/those measurements. WRONG! A little further down it says to match drill 7x. A little confusing. Needless to say, my holes are off. And I did it to BOTH of them! And if I match drill now, it will be close to being a figure 8 pattern (may or may not, but will be close). So before I order another set of tiedowns, is there any obvious fix for this that I'm not catching?
Old 09-14-2008, 08:34 PM
Webb's Avatar
Webb Webb is offline
Default Switch or flip
Can you flip them or switch sides (or do both)? If I remember correctly, they are intended to be bolted so they can be removed later for exchange if needed.
If you can't flip, switch, turn upside down...I would order new piece of aluminum and do over. Since you have access to both sides of the spare right now, you can match drill from the rear.
Any chance you got 'em switched?
btw - keep that thumb out of the way!!!
Webb Willmott
Jackson, MS
N32WW
Old 09-14-2008, 08:36 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Welcome to the wing kit! Van's really holds your hands through the empennage kit. It's a lot less with the wings, and the fuse and finish kit get skimpier. I say redo both tie downs. I don't see any other way out.
Call up Van's tomorrow morning and you will have new parts by Wednesday. You can keep yourself busy by deburring wing ribs!
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 09-14-2008, 08:53 PM
Michael Brown Michael Brown is offline
Default It Happens
I have learned to read ahead before drilling.... Check it twice and drill it once. I am just ahead of you Daniel and there is a lot more things just like this. Good Luck. Feel free to email me any questions. I have probably had the same problems you are going to run in too.
A wise man once told me..... A man scared to drill holes will never complete his project. A man that is drill crazy will complete his project, but will order a few replacement parts. It's only money!
PS... Sealing the tanks is a PITA
Michael Brown VAF #1458
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
Wings Under Construction!
Old 09-14-2008, 09:36 PM
Michael Burbidge Michael Burbidge is offline
Default RV-9 instructions were clear
I just match drilled the tie downs on my 9 last night. The instructions were very clear. They said to drill one of the top holes with the measurements on the plans and then match drill the other three. The four inside holes have to be match drilled with another part also. Still between the instructions and the plans it took me awhile before I drilled. I wish all the plans were like the RV10. From what I've seen the drawings are integrated with the instructions. Very nice.
By the way, if I was ordering new tie downs I'd get them from Cleveland. They have a set of 3 with powder coated tie down rings for $32. They have the tie down threads already cut. I was going to buy a tap and die set, but when I saw those I just ordered them instead.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 09-15-2008, 06:31 AM
danielhv's Avatar
Sounds like a good deal... ONLY because it comes with the forged eye bolts. I'm willing to bet I'll need the tap & die set eventually for something else tho. Decisions decisions...
Old 09-15-2008, 06:45 AM
Webb's Avatar
Default Tap and Die set
Yes you will need.
Tip - buy the one with the v shaped jaws because it will hold the small taps better than the one that the tap slides into and uses a compression ring.
When I put my windscreen in, I put the tap in my cordless drill and went nice and slow. Saved a huge amount of time and did a great job which also avoided carpel tunnel by twisting so many holes.
You will only use about 3-4 out of all the sizes. It's nice to have another tool "just in case".
Webb Willmott
Jackson, MS
N32WW
Old 09-15-2008, 09:31 AM
decathlon737's Avatar
decathlon737 decathlon737 is offline
Webb,
The tap holder with the compression ring has two sets of jaws, you simply slip the small tap deeper in to the next set of jaws. I fought this problem for a while till a friend showed me, yeah, i felt foolish .
Bill Woods
RV8 sold 180 hrs. of pure joy
(Nov 2018) Bought 7A Tip up
project, converting to tailwheel
slider (just because)
Thunderbolt YIO390
Hartzell BA
Steinair Panel (WOW)
Old 09-15-2008, 09:57 AM
Randy Walls's Avatar
Randy Walls Randy Walls is offline
AEX tie down stock from Van's is cheap, ask me how I know.
Randy Walls
Cessna 120
Old 09-15-2008, 10:26 AM
Webb's Avatar
Default Oh
Originally Posted by decathlon737 View Post
Webb,
Mine went into the junk tool box!!!
Webb Willmott
Jackson, MS
N32WW
