Old 09-13-2008, 11:18 PM
hydroguy2's Avatar
Default manual elevator trim
Bill has a nice labeled button for the trim.repucci trim button
Since I've been dinking around on the lathe, I started thinking of making a new knob to replace the big black elevator knob. looking at it, it appears to be plastic and pressed onto the shaft.
Anyone out there ever cut the black portion off? I want to cut it off or at least turn it down and install a new aluminum knob in its place.
Old 09-15-2008, 05:17 PM
hydroguy2's Avatar
Well, guess that's a "No". Looks like I'll be the first to cut up a perfectly good trim cable.
Old 09-20-2008, 10:38 PM
hydroguy2's Avatar
cut the black plastic knob off my trim cable a few days ago. Today after work I put the finishing touches my new aluminum knob. Here's a pic or two along with my aileron trim lever.
I'll probably eliminate the black "hold/release" piece also.
Old 09-20-2008, 10:45 PM
yakdriver yakdriver is offline
Brian, The hold and release knob increases the friction. If you remove it your trim won't hold a setting. I have mine fairly tight and it works great. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 09-20-2008, 10:53 PM
hydroguy2's Avatar
Sorry, guess i was misleading with the word, eliminate. I should have said replace.... I'll make an aluminum one. the black pieces just look bulky and out of place. plus I have a bunch of extra AL.
Old 09-21-2008, 07:03 AM
N941WR's Avatar
N941WR N941WR is offline
Brian,
Those look great! It makes me wish I had the tools you have to do such work.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-29-2008, 07:35 AM
BloomerJohn's Avatar
BloomerJohn BloomerJohn is offline
I have a spare RV6 trim cable anyone can have for $35 in case your attempts fail .
John Nielsen
www.Flight-Resource.com
RV6 w O-320 (160hp)
MT 2-blade FP Prop
Old 09-29-2008, 09:04 AM
turneraero turneraero is offline
Default Just Wondering
Just Wondering if anyone has adapted a Cessna style trim wheel to their RV. I am planing on building a console and thought a inline style wheel would work better. Any thoughts?
Jerry
Old 09-29-2008, 09:16 AM
rvmills's Avatar
rvmills rvmills is offline
Default Hmmmm...could a guy buy some of these?
Brian,
Are you considering marketing either of your new creations?
The aileron trim looks like an easy plug and play piece, and much nicer than the thin stock handle.
On the elvator trim, how's it feel compared to the stock handle with the bumps...any slipping, or do the holes make it easy to grab and turn? How hard was the replacement of the original (need to go look at mine today to see how it's attached).
Nice work, and please let us potential buyers know if you start up Hydroguy2 Unlimited Aerosports to sell them!
And Bill R, also wondering where the El Trim label-button insert came from. The combo of your button and Brian's Ail trim is pretty inviting at the moment.
Thanks guys!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 09-29-2008, 11:08 AM
hydroguy2's Avatar
Originally Posted by rvmills View Post
Brian,
Are you considering marketing either of your new creations?.........
.....On the elvator trim, how's it feel compared to the stock handle with the bumps...any slipping, or do the holes make it easy to grab and turn? How hard was the replacement of the original (need to go look at mine today to see how it's attached).
.........Bob
I have commited to making a few aileron trim levers to test the waters. not sure if I need another job. but maybe.
Haven't tested the elevator trim yet. Seems easy to grip. Replacement required, seperating the cable and knob then sawing most the black knob piece off, without ruining the shaft. Next was a little file/sander work and I ended up with a shaft with knurling intact. The new AL knob was sized for a press fit over the knurled portion. Actually pretty easy....now that it's done. The next one would go 3x faster.
