Sometimes there is a bit of a twist in the wing causing skin misalignment. Twisting and starting in the middle is sound advice. It's best never to start riveting until at least every other hole has a clecoe in it. Wing skins are somewhat different as you need to roll back the skin in order to get in and rivet. But you should have had the skin clecoed in place to drill the holes to final size. Best to clecoe every other hole, drill, then move the clecoes, finish drilling, then remove the skin for cleanup and dimpling.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
