Old 09-13-2008, 06:17 PM
rvator_md rvator_md is offline
Default Voltage Fluctuations
I decided to pull my 60A alternator to have it bench tested because I've been having some voltage fluctuations between 12.5 and 13.9. Imagine my surprise when I pulled the boot back on the output terminal of the alternator and found the insulation around the ring terminal burnt and the wire badly corroded. Corroded enough to allow me to pull the wire from the terminal end.
Now I know why the voltage was wandering. I checked the other connections and this is the only one that was corroded.
I have 575 hrs on the airplane and this is the first problem with my electrical system. This original connection was only crimped, but the repair will be crimped and soldered.
Mike Rollison
RV-6 N512RS
KDMW
Mid-Atlantic RV Wing
Old 09-13-2008, 07:00 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
We had the same problem on a 9A with about 60 hrs. Was pulling the alternator off to have it checked, when I noticed arching marks in the terminal connection. The wire just pulled out.
My 6A's terminals are crimped and silver-soldered.
L.Adamson
Old 09-13-2008, 10:07 PM
Geico266's Avatar
Geico266 Geico266 is offline
Soldering can focus vibration in the wire where the solder stops and it will lead to the wire breaking. It's better not to use solder in a high vibration environment. Try to secure the wire better and use a good quality crimper & strain relief.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-14-2008, 06:26 AM
L.Adamson's Avatar
It depends how well the wire is restrained, and how far the solder is allowed to flow into the wire strands. I prefer my method.
L.Adamson --- RV6A
Old 09-14-2008, 07:17 AM
vic syracuse vic syracuse is offline
Super Moderator
I agree with crimping and silver soldering these large connections. I've always done it that way on my airplanes. Do take the time to properly clean the solder flux residue off, and properly secure the cable, and it will last.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
