Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Interiors
  #11
Old 09-13-2008, 07:03 PM
wickedsprint wickedsprint is offline
Originally Posted by az_gila View Post
..you go with a modern epoxy primer, the wear problem will be taken care of.
Many are the correct dark green zinc chromate color.
This one is about $75 for a 2.5 qt. kit.
Rand-O-Plate Epoxy Primer (B-6433 Dark Green)
I'm sure North American would have used epoxy primers if they were readily available in the 40's....
Not a big fan of the epoxy hassle, plus I'd have to look into how well that actually provide corrosion resistance. I'm pretty well set on zinc chromate for corrosion barrier..it's proven over the long haul.
-Tony
Cheyenne WY/ Iraq
Private pilot...still in research stage for a -8
Old 09-13-2008, 07:33 PM
glenn654 glenn654 is offline
Hey Tony,
I have a couple of cockpit/panel pics I took when I upgraded my panel a year or two ago. I don't know how to post them here so I will send them to your e-mail address.
Glenn Wilkinson
Old 09-13-2008, 08:54 PM
Originally Posted by glenn654 View Post
Hey Tony,
Glenn Wilkinson
My email is the same screen name here at gmail.com, I appreciate it!
-Tony
Cheyenne WY/ Iraq
Old 09-14-2008, 01:30 PM
Rick6a's Avatar
Rick6a Rick6a is offline
.....see a picture where the interior was left Zinc Chromate colored with a black panel..something like this P51. Would there be any issues to leaving it bare like this?........
I'd like to think that if the advanced epoxy primers we have today not available back in WW11, the military would have almost certainly specified epoxy primer instead of zinc chromate. I am a fan of Akzo epoxy primer partly because of my job experience. The "McBoeing" paint shop in St. Louis used a very close derivative of it on the C-17 Globemaster III airframe. I figured if it was good enough for my employer (and the taxpayer's dime), it was a good enough for my RV.
Without any interior or carpet installed, the only place it has worn off in my -6A after 4 years is the floor directly under my heels. I used the same Akzo again on the -8 project. If I wanted a fancy interior, I'd buy a Lexus. You can't build much lighter than that.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 09-14-2008, 01:43 PM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
Yep, Charlie Kearns has painted his interior that color...was just over there today. Even my wife said "it looks like the inside of a P-51". So I guess he did a good job
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 09-14-2008, 01:44 PM
scard's Avatar
scard scard is offline
Thanks for the picture Rick. That is exactly what I'm planning on doing on the interior of my -8 project. Tanya makes the comment every time that I say it that the green is just too ugly for the interior of an airplane. Luckily I already built her an airplane with painted interior. This one is MINE .
Scott Card
CMW E-Lift
Old 09-14-2008, 01:56 PM
That looks awesome...very smooth.
-Tony
Cheyenne WY/ Iraq
Old 09-14-2008, 02:37 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Rick...
... that is what I was trying to say earlier about the epoxy primers not being around in WWII....
I use the Akzo primer myself, but I mentioned the Rand-o-Plate (and there are other equivalents) because it has the same ZC Dark Green shade as the picture in posting #1.
Can anyone verify if the WWII planes used the lighter green shade in P-51's? I always thought it was the Dark Green version of ZC....
I found this on a modeller's reference site (they seem to be the best at historical accuracy)
When the P-51B came about, it was probably painted Dull Dark Green throughout the cockpit.
The June 1944 Structural Repair Manual for all version of the P-51 calls for overall Interior Green in the cockpit, in the area extending from the instrument panel to the back of the canopy. An exception from the rule was that areas not normally visible required no finish coat. Instrument panel was specified as Instrument Black.
Any one know what color 1940's Interior Green is? A P-47 I saw in Santa Monica freshly out of a Yugoslavian swamp was zinc chromated in the yellow version... some primer actually remained.
Really interesting discussion here...
http://www.ipmsstockholm.org/magazin...colours_us.htm
http://www.ipmsstockholm.org/magazin...s_us_part2.htm
...and answers my previous question on what color Interior Green probably is....
...including a link to the Federal Standard colors...
Interesting aircraft manufacturing history.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-15-2008, 07:54 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Green, with envy
Hey Fellas:
I painted the interior of my F1 to match Gerry Beck's A-model P51 (yes, it's a tribute to Gerry and his amazing skills). The paint code is 29609ID (Nason Ful-Cryl). Apparently it is a fleet color?
[IMG][/IMG]
Could be my cheep camera, but I can't get good photos of this color interior.
Carry on!
Mark
Old 09-15-2008, 02:20 PM
mandm1516's Avatar
mandm1516 mandm1516 is offline
I'm going with a military theme and will paint the interior green as well. I'm going to go with something similar to this PT-23--a little more lime colored.
[IMG][url=http://imageshack.us][/[/IMG]
Mike
Mike Hawkins
RV-8 QB
Tail & Wings mostly done
Working on Fuselage
