Old 09-13-2008, 12:45 PM
dougweil's Avatar
dougweil dougweil is offline
Default Interior spray gun
How about a question from a repeat offender?
I will be painting the interior of my RV-7 at some point in time this winter. I need to buy a new quality spray gun (I still have my old, big, clunky 1qt suction gun). I need something maneuverable and lighter of course. I thought about a quality touch-up gun and or maybe a small gravity feed gun.
What have you folks used and do you have any recommendations. I will be using Jet-Glo's Jet-Flex interior polyurethane.
Doug
PS. I am also in the process of refinishing my battered gear leg fairings of the RV-4 and will use this gun for that also.
Doug Weiler
Hudson, WI
president, Twin Cities RV Builders Group
RV-4, sold
RV-7 completed and flying N722DW, 840 hours
Based Lake Elmo, MN (21D)
Old 09-13-2008, 01:16 PM
rocketbob's Avatar
Doug,
For the interior I use a Sharpe MGF with the 3M PPS liner system. The cup/liner is sealed and you can paint upside down with the gun, after the air is drawn out of the bag. It works fantastic for the inside of the airplane.
The 3M PPS cups are the best thing since sliced bread, and I used them even with cheap harbor freight guns.
In fact I wouldn't bat an eye about painting the interior with a cheap HF detail gun with a PPS cup. I honestly can't tell much difference between cheap HF guns and my expensive Sharpe guns.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-13-2008, 03:54 PM
RVRC's Avatar
RVRC RVRC is offline
Default spray gun
Doug,
I was told about a Kobalt gun with 8oz swivel cup for $39.00 at Lowes aviation dept. I bought one and used it to paint my interior parts, not QB, and loved it.
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
Old 09-13-2008, 03:57 PM
Mel's Avatar
Mel Mel is offline
I use an 8 oz. touch up gun with the trigger on top. It will get into some pretty tight corners.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-13-2008, 10:08 PM
DanH's Avatar
DanH DanH is offline
<<In fact I wouldn't bat an eye about painting the interior with a cheap HF detail gun >>
I did, worked fine. A swivel air line fitting lets you keep the gun fairly upright.
Dan Horton
RV-8 SS
Barrett IO-390
