09-12-2008, 09:52 PM
Stainless Braided Brake Lines
Where is the place to go for stainless braided brake lines? These are going inside my airplane. I was going to use race car lines or off road truck lines over aircraft stuff to save some money. Anybody have any suggestions?
09-12-2008, 09:56 PM
Try Bonaco. Talk to Brett for great customer service.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
09-12-2008, 10:37 PM
Bonaco
Definitely Bonaco.
www.BonacoInc.com
09-13-2008, 12:13 AM
Earl's
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
09-13-2008, 09:28 AM
What size?
What size do I use? -4 or -3? The plans use 1/4" aluminum lines for the hard line portions. So for the soft line portion what size should I order?
09-13-2008, 09:49 AM
I would also put a 12" length of ss hose at the brake calipers to faciliate removing the calipers. I just picked mine up at a local speed shop in Denver. Cut plastic tubing to length for each piece and took them to the shop. I was going to have them made but the shop had pre-manufactured lenghts that were close enough. Worked out great. I am not at home but believe it is #4.
09-13-2008, 09:53 AM
What size
I believe that if you call Bonaco, they have premade kits already measured for each of the RV models. I know they have them for the 7/8/9/10 models. He probably has the 6 models too.
09-13-2008, 10:32 AM
Brake lines
Im building a Lancair 360. I will need different lengths than the RV but the -4 or -3 should be the same. Im thinking they are -4 but wanted to see what others are using.
09-13-2008, 10:54 AM
been here awhile
Earlier this year I built a set of hoses for my RV6 and used -4 stainless braided hose and AN-like fittings from the local speed shop. They really turned out nicely --they run from the bulkhead fitting at the firewall all the way to the caliper. There is enough slack at the caliper to permit easy servicing of the brakes.
