Old 09-12-2008, 09:37 PM
sonny junell's Avatar
sonny junell sonny junell is offline
Thumbs up NEW DEBUR TOOL - At Last
Has any one used one of these. I am thinking about ordering one, I have had with the speed handle. THERE has got to be a better mouse trap than this, I mean its 2008, people come on.
http://www.blueskyaviation.net/countersink.html
Old 09-12-2008, 10:51 PM
nucleus nucleus is offline
Talking It's Great
I have used one of these quite a lot the last two years or so, I love it.
Hans
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 09-13-2008, 04:13 AM
Brantel's Avatar
Brantel Brantel is offline
I mounted a regular bit in a straight, cheap Black and Decker cordless screwdriver for all of my hole deburing on my plane.
Turns at the perfect RPM and works great.
(not this exact model but similar)
This along with Avery's adaptor works like a charm
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-13-2008, 07:02 AM
Greg Arehart's Avatar
I agree with Brian. I got a few of the cheap countersink bits from HF (they don't last very long) which have a hex shaft, and stuck them in my little Li-ion screwdriver and then work fine for big hole deburring jobs. For small stuff, I just twirl a drill bit between my fingers.
greg
Greg Arehart
N 7965A
Old 09-13-2008, 09:51 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Similar...
greg
...use here...
I found a battery (non-rechargeable) screwdriver at Home Depot for under $10.
I do find that true aircraft CS bit with a 100 degree angle seems to deburr better than the 82 dgress angle of the HF commercial bits.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-13-2008, 09:56 AM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
Have you seen the Bur-away? Cogsdill makes it. I bought mine direct a few years ago, but I think one of the major tool vendors carries it now. Try this site:
http://www.cogsdill.com/
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 09-13-2008, 02:04 PM
tmbg's Avatar
tmbg tmbg is offline
I use a 1/2" or so drill bit. Works fine. Makes my hands cramp after awhile.
Also, I use double flute reaming drill bits that don't leave much of a burr, and I usually will just knock chips off by hand on thinner material.
Ian
Old 09-13-2008, 04:16 PM
danielhv's Avatar
danielhv danielhv is offline
Joe
I'm contemplating on buying one of these... still undecided.
Old 09-13-2008, 04:20 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Thumbs down Not for me!
Tried them... JUNK for sure!
Cogsdill I'm speaking of...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 09-13-2008, 04:47 PM
rv9aviator rv9aviator is offline
Thumbs up Cogsdill works great
I would highly recommend this tool especially when building slow build wings as it deburrs both sides of the parts at the same time. This tools is VERY fragile and won't tolerate leaning the tool out of plumb when using. If you are careful you can do both wings without a problem. The only other downside is the cost but for me it was worth it.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
