Old 09-25-2005, 05:02 PM
szicree szicree is offline
Default PTT for Rear Seater
How many folks are wiring a PTT for the rear seater? I bought matching grips for both sticks, but am now wondering whether there is any good reason to hook up the rear.
Steve Zicree
RV4
Old 09-25-2005, 07:07 PM
jhallrv4 jhallrv4 is offline
A PTT in the rear hole is good for emergencies.
Then again, sometimes I have another pilot in the rear seat, and they can use the radio also.
Jeff
Old 09-25-2005, 08:03 PM
redbeardmark redbeardmark is offline
Default PTT in rear seat
If you're blabbing with other RVators on air-to-air comm and the backseater doesn't have a PTT, the backseater can feel a bit isolated.
[color=SlateGray]Mark Andrews
RV8A N598X
Old 09-28-2005, 09:34 AM
DEKE DEKE is offline
Default Ppt
I always remove my rear stick whenever giving rides to non pilots. I did put a PPT in for the rear seat and located it on the bulkhead that supports the Rollover bar. I take out the rear stick because I don't want any surprises should the passenger panic for any reason and makes an abrut control change. I also have a removeable Throttle in the rear on the left side.
Old 09-28-2005, 11:31 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Default PTT and trim thoughts rear
For my tandem 8:
I needed GIB(guy in back) to be able to talk to the flight (wingman)
Needed Young Eagles to be able to fly but not dork up the trim and PTT.
I have a switch on the panel that activates the gnd for the rear stick so I can control the GIB activities. The rear stick switch controls are dead unless I switch it on.
This sw would be unnessary for a Side by Side
Kahuna
