Old 09-12-2008, 03:54 PM
Randy Walls's Avatar
Randy Walls Randy Walls is offline
Default What's up with this
I started riveting the ribs to my RV7 spar today. After I set the rivets I noticed these "marks" on the spar, they where not there before riveting. They look like a crack but The spar is absolutely smooth, do you know what this is? They are on all of the ribs I did. I am guessing that the rivet stretched the spar slightly and the anadized layer is cracked. All of the marks run parallel to the spar.
Randy Walls
Cessna 120
Old 09-12-2008, 04:07 PM
tmbg's Avatar
tmbg tmbg is offline
that's exactly what it is... the anodization cracking.
You'll probably be able to notice similar radial cracks around the -6 rivets that are set by vans.
Ian
Old 09-12-2008, 04:17 PM
Brantel's Avatar
Brantel Brantel is offline
No problem, they all do that.... Don't worry, build on!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-12-2008, 06:11 PM
Default Thanks
Thanks for the info.
The more I do this, the more I realize how much I don't know,
Randy Walls
Cessna 120
Old 09-12-2008, 07:46 PM
fstringham7a fstringham7a is offline
Default RE:Still challenged
Randy
After 4 plus years (start 09/04/2004) of building I still get challenged with the next part of the project. Vansairforce, Van's help desk, builders web links.....many good ones on the Van's link....., a United Airlines retired AP has been my go to guy when ever for whatever, many helpers along the way, and last but not least the will to see the project to the end.
Just hang on and enjoy the ride as the RV grin is practiced with each new challenging skill is learned, each new kit ordered, each person that asks, "when will it be done", and those times you just stand back and look at what you are creating.
Good Luck in you Build.
Frank @ 1L8 ...RV7A... Painting
