Old 09-10-2008, 07:05 PM
bkc3921 bkc3921 is offline
Default Simple (I hope) Baffle Question
My aft rear baffle slightly touches the rubber on the dynafocal mount, left side. Bend it, relieve it, relieve the rubber a little, or let it rub? If the baffle is relieved, might be a little hard to seal with red permatex..any thoughts from anyone? Thanks in advance..
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
RV-12is EMP in progress!..Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
Old 09-10-2008, 07:07 PM
cytoxin's Avatar
cytoxin cytoxin is offline
trim the baffle. i would not trim the mount in any way. if it barely touches barely releive it.
William Weesner/ still kicking.
Old 09-10-2008, 07:50 PM
sportpilot's Avatar
sportpilot sportpilot is offline
Default cut and trim
Durn, thats the best advise I ever heard. Thats what they make goop for, filling in the cracks left by trimming...
Claude Stokes (sportpilot)
Finished Building an RV-10 and a Titan Tornado 2
RV10 approaching 150 hours Vans kit 40418
See Pictures of the RV10 here. http://btconline.net/~sportpilot/RV10/boatright
Waycross, Ga. Airport KAYS
Old 09-10-2008, 10:46 PM
Talking
..sorry to ask such a rudimentary question..as I get close to the end, I think I'm starting to second guess myself....
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
Old 09-11-2008, 01:33 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Not a bad question
NOT AT ALL. As they say you don't want anything shaking to touch any thing else unless you can help it.
Think about the engine shaking like a wet dog trying to get dry.
The soft seals, airbox to cowl, control cables, hoses and wires all make some transition from engine to not moving structure (cowl, engine mount, fire wall).
You really want to minimize any contact vibration has with the airframe. So some service loop or play is important. What ever you do you don't want something sold on the engine touching some thing sold that is fixed structure.
Also the baffle could cut into the engine mount rubber. Rubber is critical so keep it clean and oil and gas off them by all means.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
