Old 09-10-2008, 03:17 PM
algrajek algrajek is offline
Default Fuel tank rivet leak
I got my fuel tanks sealed and foud one rivet in each tank has a leak. I have searched the forum but can't find anythin specific.
Any way of sealing these rivets without cutting into the tank?
Al "Nordo" Grajek
Old 09-10-2008, 03:21 PM
frankh's Avatar
frankh frankh is offline
Default erm
Ya thats about it unfortunately...Cut a hole in the rear baffle, stop the leak with proseal from the inside and put a patch on.
Frank
Old 09-10-2008, 04:04 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Van's recommends green (self-wicking) loctite for the occasional rivet leak. It helps if you put a little vacuum pressure in the tank to help suck it in. I'd try this before cutting into the tank.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-10-2008, 04:11 PM
scard's Avatar
scard scard is offline
Lets just reiterate that if you decide to pull a vacuum on the tank, keep it very, very little. That tank has a lot of skin area and is surprisingly easy to collapse with negative pressure.
Scott Card
CMW E-Lift
Old 09-10-2008, 04:32 PM
erich weaver's Avatar
There is a fair amount of info on this in the archives - search on "weeping rivet".
The Loctite method appears to work successfully for very small leaks. I used it recently (so far so good). As previously cautioned - keep the vacuum low, around 13 inches of water. You can set up a simple manometer off of the vent line to measure this, as described in one of the archived eaerlier posts on this subject.
erich
Old 09-10-2008, 04:43 PM
fliier fliier is offline
I used the green Loctite method back in 2003 when I discovered a weeping rivet. I completely drained the tank, put a VERY small vacuum on it with a hand pump attached to the fuel vent, and applied the sealant. The hand pump I used was a $12 fuel pump from the local auto parts store. I did remove paint from the rivet before applying the loctite.
I haven't had a problem in the intervening 5 years.
John Allen
Old 09-10-2008, 04:45 PM
Geico266's Avatar
Geico266 Geico266 is offline
I've also used the loc tite leaking rivit fix with mixed results, but it did work on over 1/2 of the rivits I have tried it on.
Good luck. Keep us informed.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-10-2008, 07:21 PM
Jamie's Avatar
Jamie Jamie is offline
Where is the leaking rivet? I had a leaking rivet on the rear baffle. The leak was discovered after final assembly. I drilled out the rivet, vacummed the rivet out through the wing root...shoved a little pro-seal up into the hole, covered a 3/32 pop rivet in pro-seal and pop'd it into place. I have had no leaks so far.
Old 09-10-2008, 07:44 PM
Jim P's Avatar
Jim P Jim P is offline
I used thinned Pro-Seal on a leaking rivet along the leading edge. PS thinned with a little MEK seemed to work well and sucked into the tank after pulling a little vac (not too much though).
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 09-10-2008, 11:32 PM
jdmunzell jdmunzell is offline
Default while we are on the subject...
I am currently pro-sealing my left fuel tank. I am wondering if I should check for leaks BEFORE closing it up with the rear baffle. With the tank in it's cradle, cant I just fill it up with colored water to look for leaks in rivet areas hard to reach once the tank is closed up???
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
