Old 09-09-2008, 11:14 AM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Question How to protect the inner cowl surfaces?
I've been told that over time, engine oil will penetrate the inner cowl surfaces and soak into the honeycomb core. The pre-preg glass used here does look like it could be porous to me, so this looks like a valid concern.
So, do any of you here know what might be a good choice for finishing/protecting the inner surfaces of the engine cowl? Something that will seal the surface, stand up to high heat, and remain impervious to fuel/oil etc?
I was thinking about epoxy paint, and just roll it on with a thin nap roller...
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 09-09-2008, 11:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yes, straight epoxy, also reflective foil from Vans.
Try a search, this was covered more than once in the fairly recent past.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-09-2008, 11:50 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I took some spare epoxy paint and applied it until all the pin holes were filled.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 09-09-2008, 11:53 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Bill Wightman View Post
....do any of you here know what might be a good choice for finishing/protecting the inner surfaces of the engine cowl? Something that will seal the surface, stand up to high heat, and remain impervious to fuel/oil etc?
This topic along with dozens of other very helpful tips is covered in Van's "27 Years of the RVator." Typically the builder brushes in West System epoxy, some builders thin it down with up to 50% acetone. I applied it in stages using leftover resin after other projects were done. Sealing the inner cowl will not only keep liquids from soaking through the honeycomb but also provides a good base for the reflective foil tape to adhere to.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 09-09-2008, 12:01 PM
rv72004 rv72004 is offline
I dont really agree with the oil soak. Mine is bare plus foil and still looks new. 100hrs. I have a new xp360 that does not leak oil . I guess if youre using a old engine with lotsa leaks then paint/epoxy will help. Otherwise leave as is . Then again if I had one of them "pink" ones I might be persuaded to paint inside.....Luckily mine is the older green type cowl.
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 09-09-2008, 01:09 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default Thread drift - guilty as charged...
Sorry to hijack this thread, but is the reflective foil required? This is the first mention of it that I've heard. Where is it applied?
Sonny W
Boise, Idaho
RV-7A Flying!
Old 09-09-2008, 01:20 PM
Mike S's Avatar
Senior Curmudgeon
Sonny, the foil is to keep the heat from the exhaust system from damaging the cowl.
Damage can range from none, to paint blistering, to actually charring the inside of the glass.
Depends on lots of things, engine, exhaust system, etc.
I would suspect a 4 to be more prone to heat damage than a 9, just due to being cowled much tighter.
Hope this helps.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-09-2008, 02:30 PM
Hi Mike,
Thanks, that helps. Is there a rule as to how far away the exhaust should be before needing to use the foil? My pipes are very close down at the bottom by the nose gear leg.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 09-10-2008, 11:34 AM
Most definitely. Mine was slightly damaged by heat before applying the foil.
EJ
RV7 flying
