Old 09-24-2005, 01:18 PM
n468ac's Avatar
n468ac n468ac is offline
Question Dynon AOA ?? Any using it with a D10?
Any one flying with an Dynon D10 and the AOA probe? How do you like it?
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 09-26-2005, 04:33 PM
n468ac's Avatar
Bump.
RV-6A - N468AC
N468AC Web Site
Old 09-26-2005, 04:59 PM
Davepar's Avatar
Davepar Davepar is offline
From what I remember reading, the downsides to the Dynon AOA are:
1. The display is small.
2. It's not in your line of sight while landing. Some people mount the Advanced AOA right on the glare shield.
Dave
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 09-26-2005, 06:46 PM
n468ac's Avatar
I would agree with the #2, but at only $199.00 (since i already have the D10) it's alot cheaper than the AOA PRO or AOA Sport.
RV-6A - N468AC
N468AC Web Site
Old 09-27-2005, 09:21 AM
Davepar's Avatar
Very true. For $900, I'd expect the AOA Sport to do a lot more than what it does.
On the other hand, I've never heard anybody rave about the Dynon AOA functionality. There are lots of AOA Pro/Sport fans out there.
You should try posting the question on the Dynon forum.
Old 09-27-2005, 09:48 AM
Anyone read Ken Scott's RVator article this month about giving a demo ride at OSH, having to swing wide to avoid some dork who cut him off...and then tightening the turn to make the runway? I wasn't going to put an AOA in, but it's starting to sound like a great investment.
Heck, I can pay for a lot of it with the money I save by not buying a pneumatic squeezer.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 09-27-2005, 11:02 AM
cjensen's Avatar
cjensen cjensen is offline
buy the pneu squeezer to finish the build, then sell it to buy the AOA!
i think AOA's are well worth the money. i've haven't flown one, but from what i've read, i will have one in my airplane in the end!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 09-27-2005, 12:23 PM
jimrobinette jimrobinette is offline
Default AOA-one of the best instruments
AOA provides an excellent cross-check to optimize performance and safety in almost all aspects of flight! It is useful in monitoring the margin above stall speed throughout the entire envelope. It is also a quick reference for setting max endurance, max range, approach speeds, and best climb angle speeds.
AOA, unlike airspeed, gives the same indication of stall regardless of weight or AOB. Since apparent weight increases with AOB, stall speed increases in a level turn, but most people don't relate increased AOB with increase stall speed, hence the dreaded approach-turn stall. The AOA indicator gives you the indication of where you are at at that moment, whereas each AOB has a different stall airspeed. Much easier to look at one instrument and see exactly where you are than interpret an airspeed.
For the landing pattern, AOA allows you to fly one instrument and therefore not have to worry about changes in weight, flap position or AOB. No need to worry about different landing speeds at gross or near-empty weight or if you forget to set the flaps.
Great tool that I will have in my airplane.
Take care,
Jim
Old 09-27-2005, 12:40 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default No sound
The Advanced Flight Systems AOA talks to you: "Angle - Angle - Push" but I don't believe the Dynon AOA does this in the D10. Dynon have promised it for future models, but I don't know if they have delivered yet.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 09-28-2005, 08:50 PM
n468ac's Avatar
thanks for all the replys
RV-6A - N468AC
N468AC Web Site
