09-05-2008, 05:20 PM
Problems with building at the beach??
I was wondering if there was any problem with building in a salt-air environment? I may have a shot at starting a build next year but it would be on the coast of Northern California (in Monterey Bay). Not a bad place to live, for sure, but would that be a drawback to the project? I am worried that the marine layer or just the salt air environment might make this a bad idea.
Any opinions?
Thanks!
09-05-2008, 05:52 PM
Beach House
Just keep your tools oiled. BoeShield T9 is your friend.
neal
3/4 mile from Navarre Beach surf...
Neal George
Navarre, FL
CherokeeJet N9586J
RV-7 N8ZG (all the loose ends)
Continental Aerospace Technologies, Product Support
09-05-2008, 06:23 PM
My workshop is maybe 600 feet from the Indian River on Merritt Island, which is briny. The ocean is a mile or so across another very narrow barrier island. My steel tools will get rusty if left out, but I have no problems with the aluminum components. Steel parts, once I break them out, will show signs of rust if I don't prime them.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
09-06-2008, 05:00 AM
Thanks for the feedback. But doesn't this seem like a larger problem then? I wouldn't be so concerned about my tools. I am more worried about the plane, obviously. I can't see priming everything (or certainly not always fast enough to prevent the damage). And what about an electrical system ...all the contacts in the wiring and whatnot. And even just the instruments and avionics? If the tools are rusting, aren't you certain to pick up some damge in these other areas as well?
09-06-2008, 05:41 AM
Andy,
I also live a block from the Atlantic Ocean. Aviation grade electrical wire is "tinned" (coated with a thin layer of solder over the copper strands) to prevent corrosion damage. Use aviation quality wire & connectors and you will be fine. I store my avionics in the A/C when not needed for fitting or wiring as a precaution. I also Alodined and epoxy primed all my parts prior to riveting. I'm a rather slow builder, yet had no issues with corrosion of the parts prior to etch, Alodine and priming. My wings took me over a year to build. They were raw until after all the deburring and dimpling. I had no problems.
The Central and Northern Pacific coastal areas do not seem to exhibit as much of a corrosion issue as we have here in SE Florida. I doubt that you'll have any problems. Enjoy that beautiful area of the state.
Charlie Kuss
09-06-2008, 05:51 AM
Thanks Charlie. That is comforting!
09-07-2008, 07:50 PM
Has anyone near the beach noticed their clecos rusting? I just started noticing this - a couple have started to gather some rust and won't close all the way...
09-07-2008, 08:30 PM
I've lived over the road from the South Pacific / Southern Oceans for most of my life, and I'll agree that corrosion is a serious consideration. The coastal wind blows salt and sand into most everything. Indeed, I'd say we're essentially talking about a marine environment, sans the salt water immersion. Everything ferrous starts to rust, most of everything else corrodes in some way... It's a tough place for metals.
SteelMike, I'd discard those that are no longer closing, and start treating the remaining clecos the same way you treat your tools. Are some brands better than others in this regard?
To anyone else, if we can't prime everything on arrival, is alodining all of the aluminum components on arrival a sensible course of action when building in coastal locations?
09-07-2008, 09:46 PM
Mike,
I've noticed rust on some of my clecos that are 50 miles inland from the beach in Upland! Must be the Southern California smog.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
09-08-2008, 06:34 AM
The aluminum comes with a protective coating. It should be fine until you build it. You should alodine after you match drill and cut all parts. All our clecos started to rust. My garage is about 150' from the salt water marshes. Some tools started to rust also. Another thing that will screw up all parts and tools is pool chemicals. Keep them away from you plane.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
