Old 09-04-2008, 10:22 PM
Noah's Avatar
Noah Noah is offline
Default Canopy Release Mechanism - Alternate Design
View Video of Mechanism Operating
I roughed in this canopy release design tonite with a vertical actuation handle (removed one part of the Tee handle making it an "L". Note the extension spring to keep the pins engaged. I'm aware of the debate about using the canopy release in flight (not looking to rehash that again). I'd like to keep some form of release for maintenance and, more importantly, for emergency ground egress when parts might be crumpled.
I know some other guys (Davepar, Chad Jensen?) may have done something similar? Not sure these made the cut when avionics started going in though.
Do most radios extend past the subpanel? How about most EFIS'? Any other thoughts?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 09-05-2008, 06:34 AM
Mel's Avatar
Mel Mel is offline
We've done quite a few like this. Works fine. Many radios go through the sub-panel, but they are to the right of the mechanism. Most EFIS are not that long.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-05-2008, 07:21 AM
Sam Buchanan's Avatar
been here awhile
Here is my version of the modified canopy release from 1999:
During the course of nine years of flying and 2 1/2 panel rebuilds I have never had a need to remove the canopy. If doing this again, I would leave out the canopy release so the space would be available for whatever avionics might go there. The release would be of no value in the aftermath of a crash.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 09-05-2008, 07:42 AM
cjensen's Avatar
cjensen cjensen is offline
Yep, mine is modified like that. More like Sam's without the spring though. No problems with anything interfering yet...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 09-05-2008, 09:30 AM
Noah's Avatar
Thanks for the input guys.
Sam, it's unclear what the arm connects to on the left side in this lo-res photo. Is there a spring keeping the pins engaged? What does that arm connect to??
For guys who didn't use a spring, how do you ensure that the thing doesn't open from vibration?
Highest Regards,
Noah F, RV-7A
Old 09-05-2008, 09:46 AM
been here awhile
It's just a tab with a hole in it that can take a bolt, pin, circlip, or whatever to lock the mechanism. However, I don't think I ever put anything in the "lock" (been nine years....slept a couple of times since then....). There is enough friction in the canopy pins to hold everything tight especially when you consider aero loads on the canopy trying to lift it off the plane and the pressure exerted by the canopy locking mechanism. It takes a significant effort to turn the release handle when the canopy is closed.
Sam Buchanan
RV-6
Old 09-05-2008, 10:01 AM
cjensen's Avatar
You got that right!!! I almost can't turn the thing with my hands when the top skin is in place...a pair of pliers makes it easier to turn, but it's not going to vibrate past the over-center "lock" on it's own, even without some sort of lock installed.
Chad Jensen
