Old 09-03-2008, 11:16 AM
Chappyd Chappyd is offline
Default Transponder terminology ?
Hi All,
I got a few days off and started working on avionics harnesses. I have a Narco AT165 transponder, and looking through the manual raises some questions.
In the pinout diagram, there are 2 leads labeled as external suppresion, one + and one -. What are these?
Will this unit work with Narco's AR-850? Haven't bought that yet.
I have a call into Narco, but can't get a body on the phone-yet anyway.
Would appreciate any input from anyone who can help.
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
Old 09-03-2008, 11:26 AM
tmbg's Avatar
tmbg tmbg is offline
That's an interconnect for either another transponder or a DME unit, I believe. That allows the two pieces of equipment to coordinate their transmits so as not to overload the other.
Ian
grover grover is offline
Default suppression
L band equipment tends to talk over other L band equipment (xpdr, dme, tcas etc). the suppression lines go to other L band boxes, and basically tells them not to transmit while another L band box is transmitting.
james kleen
savannah
RV8sp
- RV3
Old 09-03-2008, 11:35 AM
Cool, thanks!!
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
Old 09-03-2008, 11:58 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation This might help...
..the Installation Manual is here -
http://www.narco-avionics.com/manuals/036090620kvs.pdf
They call the signal "DME SUPPRESION" (the "other" L-band device mentioned above) and say it may be connected.
So, if you don't have a DME just leave this wire floating. The second labelled wire you mention (the "-") does not seem to be in the IM pin-out, so it probably one of the ground connections.
The IM pin-out is on page 15 of the above document.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-04-2008, 12:56 PM
I've noticed that among the manuals for the various versions of the AT-165, there are a bunch of small differences.
Update on my call to Narco- they called 2 times today before lunch while I was out. Fella named Tom left me his direct #. I called him back and he was very helpful with all my noob questions. I not a very big avionics guy, and I'm at the beginning of a very big learning curve. I chose Narco because I had some of their equipment in my Mooney and it always worked well.
So here's a shout out to Tom at Narco. Thanks!
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
