Old 08-31-2008, 03:10 PM
philcam's Avatar
philcam philcam is offline
Default Does heat effect Pro-Seal?
I'm storing my tanks in my attic for the time being.
As you might imagine, it is quite hot in the humid Texas summer up there.
Will the heat cause any problems with the pro-seal?
Yeah, I know it's hot in a hanger, but I think my attic is much hotter.
Phil
Phil Campbell
Eagle's Nest Projects
VAF # 1043
Builder # 82699
DFW Metromess
Old 08-31-2008, 03:41 PM
Transporter Transporter is offline
Default Tech Data Sheet
Just re-read the tech data sheet...regular tank sealant is rated from -65 to +250 degrees F...
http://www.flamemaster.com/Technical...S3204R_TDS.pdf
How hot is hot in your attic?
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
