Old 08-27-2008, 06:22 PM
Geico266's Avatar
Geico266 Geico266 is offline
Default IO-540; What Is Normal Oil Pressure?
I've been looking for info and could not find anything on a search for info just on the IO-540.
I just adjusted the pressure screw so now my readings are; Takeoff (oil temp 100F) Cruise: 75 PSI, Hot Idle: 24 PSI
I still have 2-3 turns to go if I need it. It's the idle pressure that has me concerned. Is 24 PSI too low? If I bump the throttle it goes to 35PSI right away. I'm I worrying too much?
What are your readings with the 0-540 or IO-540?
Thanks in advance.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-27-2008, 06:49 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
The operators manual that I have says
All models except -F -J -N, Max 90 Min 60 Idle 25. -F -J -N, Max 90 Min 55 Idle 25
RV6 built and flying
Bearhawk Patrol plans purchased
Old 08-27-2008, 07:02 PM
Geico266's Avatar
All models except -F -J -N, Max 90 Min 60 Idle 25. -F _J -N, Max 90 Min 55 Idle 25
Thanks man! I feel better now. I can live with 1 PSI below min.
Old 08-27-2008, 07:08 PM
Mel's Avatar
Mel Mel is offline
Normally idle oil pressure is not critical. If you have enough pressure to keep the lifters pumped up, there will be enough for the bearings. Nothing is carrying much load at idle.
I wouldn't worry about a pound or two at idle.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-27-2008, 07:12 PM
Geico266's Avatar
Thanks Mel, they are hydraulic lifers, that makes sense. This is just one of those things that rattles around in my brain. The pressure was 65 PSI @ cruise so I bumped it up to 75 PSI. It sure is nice to know everything is hunky dory.
Old 08-30-2008, 11:54 AM
dmaib's Avatar
dmaib dmaib is offline
Default I0-540 Operatiing Limitations
Where does one find all of the operating limitations for an I0-540. Oil press, Oil temp, CHT, etc?
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 08-30-2008, 03:04 PM
Mel's Avatar
Mel Mel is offline
It's all in the operator's manual.
Old 08-31-2008, 06:19 AM
mahlon_r mahlon_r is offline
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/ffae5a2bb5506dcc8625747a00650001/$FILE/1E4.pdf
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 08-31-2008, 06:56 AM
smokyray's Avatar
smokyray smokyray is offline
Default 540's Rule!
Larry,
I have found on my Rocket's IO540 C4B5 that Multi Vis oil will change the numbers slightly on hot days, cooler temps, higher pressure at Idle.
Smokey
HR2
PS: Yep you worry too much...
Let's have fun out there!
Old 08-31-2008, 06:58 AM
Geico266's Avatar
I'm running Shell 15w-50 now. Pressures are now in the normal range. Thanks to Bart & Sue at Aero Sport Aircraft Engines. They are the best!
