Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 08-27-2008, 02:56 PM
vonjet vonjet is offline
Default Hartzell Prop Hub question
I need to get longer bolts for my Hartzell hub that bolt up the spinner backplate. These are 4 long bolts that go thru the hub and bolt up to the spinner backplate.
They are very tight in the hub and I dont want to do any damage. I wasn't sure if they unscrew or how they come out.
Does anyone know how to replace these?
Old 08-27-2008, 03:17 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default longer bolts
What hub model do you have?
Sorry I can't help with the aqusition of longer bolts, but FYI I've never needed to do this or heard others with this issue. The back plate is about 0.062?. No room at all for the backing plate? I would not remove those bolts my self, but it may be mo big deal. Good Luck.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 08-27-2008, 03:45 PM
Kahuna's Avatar
Kahuna Kahuna is offline
ASSumming you have a compact hub, if you see a bolt with the nuts off, they shoudl come out. Try a punch and persuasion.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 09-04-2008, 03:33 PM
PropProfessor PropProfessor is offline
Kahuna is right, just remove the nuts and carfeful using the punch, RTV is what is causing the resistance. Any prop shop can sell you longer bolts.
Old 09-04-2008, 04:15 PM
Gary Bricker Gary Bricker is offline
Thumbs up Gary Bricker
Try the prop extension folks at Sabre for bolts
Old 09-17-2008, 06:23 AM
yak-52 yak-52 is offline
have 4 long bolts here as removed from a prop with a spinner mount if needed.
jackumac@comcast.net
