Old 08-27-2008, 08:34 AM
N941WR's Avatar
N941WR N941WR is offline
Default Loose wheel pants brackets
During my condition inspection I found both wheel pants brackets where loose. This allowed my wheel pants to move around.
During pre-flights, I thought the holes holding the wheel pants where getting enlarged and would need some fiberglass work. This was not the case.
After removing the wheels to repack the bearings, they were very easy to tighten. My only concern is if they will they work loose again.
Has anyone else run into this?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-27-2008, 01:15 PM
vic syracuse vic syracuse is offline
Super Moderator
Bill, I noticed this same phenomenon on my RV-10. I finally ended up using Heat nuts instead of the the fiber nuts, and I double-nutted them. That seemed to fix the problem.
I just checked mine this past week end on the 7A and they were not loose (just over 53 hours).
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
