Old 08-26-2008, 01:38 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Better weatherstripping????
Doing the final install on my 9a tipup. Have seen lots of builders who hate the vans cheap white stripping. The adhesive is blistered off in about 1/4 of the length of mine, dont want to use it.Thought somebetter products were tossed around here before, i think from Ace hardware if i recall, cant find link. ANYONE have any better weatherstripping ideas to seal up tight and last and stick better than the cheap stuff vans includes? Thanks.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 08-26-2008, 01:49 PM
kentb's Avatar
kentb kentb is offline
Default Rick, I got mine at ACE.
I can't remember the brand, but I bought a couple different types, all close cell weather stripping.
1. Round - cut these into about 1 inch pieces and glued them on the back side of the baggage compartment into the groves. When the screws are tightened they squish flat and seal this area.
2. 1/2x3/4 pre-glued on one side. This went under the sides of the canopy.
3. Something a little smaller then the above. I used it to fill in areas that the above didn't quite take care of.
I used the Vans supplied white strip on the front of the canopy area.
I haven't found any problem with air leaks, but I don't fly in the rain very much, so mine might leak.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 08-26-2008, 03:44 PM
AlexPeterson's Avatar
http://www.vansairforce.com/communit...ad.php?t=23520
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 08-26-2008, 04:33 PM
Default Thanks
Mucho appreciated. I will go to Aircraft Depot in the am and try and get some MD brand WS 108 and some other foam strips for the canopy sides and keep plugging away.
Cheers.
Old 08-27-2008, 07:13 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default try boat stores
try boat stores. They have good selections of weather stripping especially sail boat stores.
