Originally Posted by tommylewis
yes the resistence is the same, BUT there is a difference in the orientation of the left vs the right. I had to buy a replacement because I did not notice they were different until too late and then had to buy another.
good luck,
I think the only effect you would see (provided the float moved over it's range) would be a revesal of the direction of resistance change from high to low fuel levels.
If you are using a newer EMS (such as a Dynon) there is a good chance that this will make no difference since the actual reistance would be calibrated for each tank, and the EMS does not care in which fuel level direction the sender resistance increases.
Check your manuals...
Of course, if you are using Vans senders (or similar automotive ones), then the L and R orientation does matter...
