Old 08-24-2008, 10:49 PM
floydpackard floydpackard is offline
Default manual aileron trim won't hold
How do I tighten the manual airleron trim. When I am in cruise flight the airleron trim slips back to neutral. It seems like I need a little more friction.
Floyd
Floyd Packard
bought flying RV7a (Roberta's)
Kennewick WA
New pilot, learning and loving it!
Old 08-24-2008, 11:12 PM
DickDe DickDe is offline
Default Adj Aileron Trim
The UHMW plastic bearing block the trim lever shaft is mounted through and pivots in is a block with a hole drilled in it & one side is split. A bolt across this split is tightened to add friction to the shaft. You will have to lift the seat pan which also covers the aileron control tubes in the fuselage to get at this block. It is a very simple mechanism and it won't take much of a turn to tighten the friction...maybe a 1/16th of a turn.
Dick DeCramer
RV6 N500DD 300 hrs
RV8 wings almost done
Northfield, MN
Old 08-25-2008, 06:17 AM
Jimd Jimd is offline
Default More
I have experienced this trouble on two different RV's and am about to install my own for the inspection and wonder if splitting the other side would help any? Or, what about putting a little valve grinding compound in the block saddle at assembly to add some grit?
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 08-25-2008, 06:23 AM
Webb's Avatar
Webb Webb is offline
Default cut slot wider
One pass through the bandsaw isn't wide enough. Take it out and run it through again. It will tighten up nicely.
Webb Willmott
Jackson, MS
N32WW
Old 08-25-2008, 11:05 AM
Noah's Avatar
Noah Noah is offline
Webb is right. Depending on the width of your saw kerf, the edges of the slot may contact when the bolt is tightened, thereby limiting the resistance. Widen the kerf in the UHMW, and tighten the bolt some more. Should be able to get all the resistance you need.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 08-25-2008, 11:56 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Webb and Noah may be right, but I doubt it. Chances are the kerf sides aren't touching, and if they are not, then simply tightening the bolt will do it. If the kerf is bottomed out then you will have to widen it, but don't do this unless you have to.
The UHMW blocks do wear over time and eventually you might have to widen the cut, but with the amount of hours on that particular plane, I seriously doubt it.
Always check the simple, cheap stuff first.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
