Old 08-24-2008, 09:46 AM
skyfrog's Avatar
skyfrog skyfrog is offline
Default Flea Market Find - Static Air Test Kit - Worth Anything?
I just picked up a Static Air Test kit from Omni Air, Inc. at the local flea market. It appears to be functional but hasn't been calibrated since 1990.
Do you think it's a useful find?
John Edwards
jedwards@digital.net
VAF #1089
Old 08-24-2008, 10:16 AM
grover grover is offline
Default keep it
may not be in cal, but great tool for troubleshooting, leak fixing, etc.
james kleen
savannah
RV8sp
- RV3
Old 08-24-2008, 01:36 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Hey Jon, when you get tired of bumping into it in the hangar, I'll take it!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-25-2008, 01:05 AM
SteinAir SteinAir is offline
Get it calibrated and you'll find it extremely usefull! Without having it calibrated it might end up being almost useless. We use ours all the time....and just had to replace the altimeter portion of it due to a wee little case leak in the instrument....which made pitot/static checks worthless!
For example, you can hook it up to your EFIS and make your airplane "fly" through the air, climb/descent, etc.. You can do the same to your Autopilot for testing, transponder and more. BUT - get it calibrated to make sure it's good. Calibration could be as low as $150, all the way to $500 or more if it needs work or guts replaced. We just had our Mode S transponder box re-calibrated and it was less than $500...but we have to do that every year to keep ole' Mr.FAA happy! If you're going to bumb around and use if for personal stuff, I'd have it calibrated initially, and then see how it goes from there.
Stein
Old 08-25-2008, 08:04 AM
skyfrog's Avatar
Default Thanks
I appreciate the information, but where does one get it calibrated. Is this something any avionics shop can do?
John Edwards
VAF #1089
