08-23-2008, 05:36 PM
Probe wire routing & secure
It would help me out a lot if a few of you that had them could post some pics of how you routed and secured you EGT & CHT probe wires firewall forward. Thanks in advance.
08-24-2008, 06:38 PM
Sorry, all my pictures are old school film type. Van's carries an item called C-606 Link. I will double check the p/n tomorrow when I am at the hanger...
It is a steel link, about 2 inches long, and has a #12 hole in each end. I think my initial one came with a wiring kit, and is used to attach the starter electrical cable to one of the sump bolts. I liked the links so much I ordered 10 of 'em and used them to secure the EGT and CHT wires firewall forward. Oh, I also powder coated them.
On the lowest screw position on each valve / rocker box cover, I used one of the links. The hole in the link was enlarged to 1/4in. to fit the screw thread diameter. A washer or two, whatever was needed, was used as a standoff to clear the lip of the box cover. The lower hole of the link was used to attach a cushion clamp and the wires that passed by that area.
08-24-2008, 07:39 PM
That sounds like a good idea. I'm fuel injected with a lycomming horizontal sump and have been thinking of routing back inside the tunnel formed by intake tubes cylinders and case. That way the wires should be in an area of good cool airflow. I'm considering using the intake tubes as a tie point with standoffs and wire ties, but the point of this thread is to get as many ideas as I can and then perhaps blend them into something I can use.
08-25-2008, 12:19 AM
photos of my O-360 RV-6A setup
I routed the probe wires outside the cylinders on one side and underneath the cylinders on the other side. First engine run planned in next couple weeks so not yet flying but this is what I did and we'll see how it works in flight hopefully very soon.
Right side routing:
Left side routing:
Link to other photos of the probe wire routing:
http://rv6aproject.ckhand.com/panelA...ctricalPg3.htm
Chris
RV-6A, almost ready for inspection & first flight
Mountain View, CA
08-25-2008, 05:28 AM
As an aside....
......what prevents those automotive type spark plug leads from vibrating off, Chris?
Curious,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
08-25-2008, 08:21 PM
Thanks to both of you that replied. Your input has helped me out a lot. This afternoon I came up with my answer and must give credit to Frankh for showing me the automotive fuel line stand off tie down thing a ma jig a couple of months ago.
08-25-2008, 08:46 PM
auto style plug leads
Pierre -
I haven't seen anything other than the regular "snap-in" clip in similar installations but open to suggestions if there's something more I should do. Easy enough to replace on inspection if it starts to feel like one of them is loosening up but initial fit is a pretty firm engagement.
How about others with electronic ignitions running auto plugs; anybody had problems with plug leads vibratiing off?
Chris
RV-6A
08-25-2008, 09:59 PM
I know a guy that lost a plug wire on his ultra light. He saftey wires them now.
08-26-2008, 02:53 AM
A pull-tie around the base of the boot works for better grip.
08-26-2008, 10:55 AM
I ended up making my own spark plug wires for my lightspeeds. Because I didn't like how close the wires were going to the exhausts, I used straight connectors for the bottom plugs. These use the same kind of boots you'll see on a dragster; they grip the entire length of the outside of the plug and take quite a bit of pulling to remove. I'm not worried about them, but I may go back and safety the angled connectors at the top plugs. Anyone got a picture of how they safety them?
EAA Technical Counselor #5357
