Jim,
I had seen the MC-5 in a couple of RV-8, so I bought them. Unfortunately, I couldn't find a way to use them on my plane -- I found there was a little too much re-engineering to do because of my particular pedal extensions and some other geometry issues. (As I recall, the MC-5s would hit the pedal weldments when the brake pedal was pushed, since they're so much wider than the stock ones.) I ended up using A-600 screw-in reservoirs mounted on the stock master cylinders, and this looks like it'll work fine, although with either method (A-600 or MC-5) you will end up losing that forward hole in the slide bar.
As far as the differences betwwen the MC-5 and MC-5A ... According to the Matco website:
"The MCMC-5 master cylinder measures 8.25 inches from end to end and 7.7 inches from mounting hole to mounting hole. A 0.625 inch diameter piston is used. Available stroke is approximately 1.388 inches and displacement is 0.43 cubic inches."
"The MCMC-5A master cylinder measures 7.7 inches from end to end and 7.2 inches from mounting hole to mounting hole. A 0.625 inch diameter piston is used. Available stroke is approximately 1.19 inches and displacement is 0.37 cubic inches."
Hope this helps!
Buck Wyndham
Northern Illinois
RV-8 N18XL
