Old 08-23-2008, 09:49 AM
rv7-ksff rv7-ksff is offline
Default EGT rise/CHT drop IO360 RV-7
In cruise I noticed a fluctuating EGT in #2. It would rise 50-100 deg and fall back to normal operating temp. At one point the rise peaked and triggered an alarm on my DYNON 180. Initially thought it may be erroneous reading from probe, but then also had concurrent shock cooling alert on same #2 CYL for just a moment. Reducing power seemed to slow down the fluctuations. I have since pulled the plugs out and they look normal. All fuel lines appear tight and no leaking fuel is evident.
Looking for suggestions......
Old 08-23-2008, 11:07 AM
vic syracuse vic syracuse is offline
Super Moderator
You might check the probe and the wires going to it, especially if you didn't notice any other fluctuations, such as fuel flow or noise.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 08-23-2008, 11:45 AM
Vic
No other fluctuations, no noise, fuel flow was normal, but there was a reduction in same #2 cht. Haven't checked the probe yet. Going to change the plugs on #2 and test fly and if that doesn't change anything will next try to swap the probes out..... thanks
Old 08-23-2008, 11:55 AM
az_gila's Avatar
az_gila az_gila is offline
Question Intermittent problem with...
...the injector on that cylinder?
Going way too lean, more EGT and less power/CHT...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-23-2008, 01:19 PM
airguy's Avatar
airguy airguy is offline
Agreed - if you saw both CHT and EGT change at the same time on the same cylinder, you've either got spark or mixture issues. My bet is an obstruction in the injector causing it to go lean.
Old 08-23-2008, 03:52 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Next time you notice that happening, try a mag check and see if it does it on one or the other or both mags. Low CHT/ high EGT means gas is burning in the pipe and not the cylinder, which could be a mag problem. However this is often accompanied by some engine roughness. Did you notice any roughness?
What kind of ignition system do you have and how many hours on it?
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 08-24-2008, 11:04 AM
osxuser's Avatar
osxuser osxuser is offline
Also look at perhaps an induction leak. Usually running ROP you'd see the cylinder get hotter, but if you near peak or LOP, then it would get cooler. Typically not something that's intermittent either, but I've seen some bad gaskets or loose hose clamps on the induction tubes do that kind of thing before.
RV4 wing in Jig @ KPOC
RV7 emp built
