Old 08-22-2008, 06:19 PM
szicree szicree is offline
Question Hose from pump to carb
My understanding is that the hose from the mech. pump to the carb is just that, but why not use metal tubing with flares at each end?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 08-22-2008, 06:35 PM
rrd1_99 rrd1_99 is offline
Default Subject to breakage..
All lines forward of the firewall should be flexible, as the vibration and relative motion of the engine will work harden any metal tubing, causing failure and that would be a bad bad thing with a fuel supply line.
Roger Barnes
-9A slow QB
La Grande Oregon
Old 08-22-2008, 06:39 PM
But this line runs from the engine to the engine. Furthermore, fuel injector and primer lines are hard.
Steve Zicree
Old 08-22-2008, 06:48 PM
RV6_flyer's Avatar
Fuel injection lines are Stainless Steel. Copper is used for primer lines and they are typically replaced at overhaul time because they get brittle and will crack. Yes they can be annealed but typically it is just easier to replace. Primer lines typically will not stop the engine when they fail. They fail and will typically suck air making the cylinder lean or if they are under pressure, the fuel is a small amount and then all you need to worry about is the FIRE from the fuel on the HOT exhaust and engine.
BEST practice is to avoid the use of hard line and use hose from the fuel pump to the carb. It is done that way on fuel injected engines.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-22-2008, 07:10 PM
scard's Avatar
scard scard is offline
Many of our tubing materials, just being attached in a vibratory environment, even without obvious major movement, will still fatigue at a surprisingly rapid rate.
Scott Card
CMW E-Lift
Old 08-22-2008, 07:30 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default I vote for flexible line
In may of this year I had a failure of a rigid aluminum line between a fuel flow transducer, mounted on the engine mount and the fuel pressure transducer located on the firewall, nearby. http://www.vansairforce.com/communit...ad.php?t=29683
There was a crack right at the edge of the sleeve of the fitting. I replaced the rigid line with flexible line.
All I can come up with is that the distance was enough for some vibration to cause the failure. For the long run to the carb I would only use flexible line.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
