Originally Posted by hecilopter
Bob,
Thanks for the reply. There are spacers on the mounting bolts between the hub and the bulkhead. You can just see these in the first picture. I used the 2 wooden clamp technique already to rotate the prop to coarse pitch and check it and there is plenty of clearance there. Any other ideas?
Here are a couple of possibilities:
1 - Rivets over driven or over squeezed such that no yield is left in the fastener - possibly but not probably, even fractured
2 - The blades you have are 7496. Van and Hartell have now gone to a 7497. I have performance charts from Hartzell that show the 7497 efficiency drops off more than your 7496 at higher aircraft speed. The 7496 efficiency peaks at ~87.9% at ~185 KTAS and drops off only to slightly to ~87.8% at 200 KTAS. The new 7497 peaks at ~85.7% at 170 KTAS and drops to ~84.3% at 200 KTAS. I asked why about this and I was told that testing drove them to the thicker and additional mid-blade camber 7497 as a better fit for the higher horsepower applications and it provides additional stiffness. I asked about the availability of the 7496 because I am interested in speed and I was told that they may no longer be available (I haven't verified that). OK, so you may be experiencing difficulty with the rear bulkhead rivets because of the propeller you are using.
Bob Axsom
