Old 08-21-2008, 03:41 AM
ignacio ignacio is offline
Default Clean up after storage
WELL IVE HAD MY WING OUT UNDER THE PORCH COVERED UP FOR A FEW MONTHS WITH ONLY THE TOP SKINS RIVETED ON. NEEDLESS TO SAY THERE IS STILL PLENTY OF DUST IN THERE. DOES ANY ONE KNOW OF A GOOD NON COROSIVE CLEANER THAT I CAN USE TO WIPE AWAY ALL THE DUST, PRIOR TO INSPECTION AND CLOSE UP. SIMPLE GREEN, AV8???. THANKS
Old 08-21-2008, 06:18 AM
b17fe's Avatar
b17fe b17fe is offline
Ignacio,
Try "Dawn" dish washing soap and water (more water than soap).
A pump up sprayer should do the trick.
Then rinse well.
Mild ... but will cut grease etc.
This is what I use to prep large parts before self etch priming.
Steve Monigal
81604 Fuse (SOLD)
Old 08-21-2008, 06:38 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
The non- corrosive "aviation" version of Simple Green is now sold at Home Depot. It comes in a blue spray bottle, and say's "Boeing spec" on the front of the bottle. It's less than $6.00. It's either found on the house/office cleaning rack, or with vehicle cleaning products.
L.Adamson
