[quote=mr scout;249734]I have a 6A slow build in my hangar that had 90 hrs on it before a truck ran into the end of one wing and attempted to shove the center section out the other side. Both wings were destroyed along with damage to the horizontal no prop strike.
I had decided to use it as a donor and started building a 9
Originally Posted by mr scout
A friend came over the other day and suggested I roll it upside down, cut out the center section and use 9 parts to rebuild the entire center section change the engine mount add the empenage and tail wheel for the 9
Attempting something like this would save you no time and it would probably actually take longer
Is this a really a viable Idea?
No
do they share any likeness?
Very little (the firewall is close to the same) Actually, structurally they are quite similar but dimensionally they are very different (parts look similar but are all different dimensionally).
or should I just continue with plan A, use it for parts and keep on building.
You are already using the best plan.
