Old 08-20-2008, 02:02 PM
nharris25 nharris25 is offline
Question Where to take engine parts.
I am doing a major on an O320-E2A. Where do I take my engine parts for inspection and machining? I think most of this stuff is done in Tulsa, OK, but am not sure of the names of the companies doing the work.
Nick Harris
Old 08-20-2008, 02:12 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Divco for the case... Aircraft Specialties for the rest, ask for Bob Merrell.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 08-20-2008, 02:13 PM
Brantel's Avatar
Brantel Brantel is offline
Yep,
Here is a list of A.S. services and prices...
http://www.aircraft-specialties.com/mach.html
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-20-2008, 03:00 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I'm looking to send cam/crank/rods/gears/lifters/cylinders to ECI and my case to Divco. I haven't had any experience with either company yet, so I can't offer any advice.
http://eci2fly.com/pages/services.aspx
Does anyone have any experience with the Freedom cylinder overhaul from ECI?
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 08-20-2008, 03:04 PM
rocketbob's Avatar
I just sent out this morning a couple of big boxes of IO-540 steel parts to Aircraft Specialties, case and cylinders to Chuck Ney.
ECI is also a good choice for overhauling steel parts.
The rest of the parts (sump, intake tubes, etc.) are all going into a hot tank at a local automotive engine shop for degreasing and stripping.
Regards,
Bob
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-20-2008, 05:16 PM
CESSNADON CESSNADON is offline
Rick Roman's has an excellent reputation inspecting and reworking the metal parts. I would buy NEW Lycoming cylinders rather than rebuilding the old. The cost difference in next to nothing and Lycoming cylinders have an excellent reputation. My case was sent to Divco. They inspected, repaired and CW all of the Lycoming SB's. There are a couple of upgrades you can do to the case to make it even more bullet proof.
Regardless of who does the work... Inspect and measure everything before you reassemble. Contrary to popular belief.........Repair Stations are not infallable and they produce crappy work from time to time.
Also make sure that you have a mutual understanding of what is to be done for what money.
You can upgrade to 160hp when you overhaul. I believe it is different pistons and a different pitch on the prop.
Old 08-20-2008, 06:17 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default When I surveyed the forums . . . .
When I went looking, I found:
Aircraft Engine & Accy for my crank, gears, rods. Talk to Greg. Progress reports, fast service, on or below quote. Pleasure to deal with.
http://www.aea-precision.com/
Crankcase Services had zero complaints - Divco, well, the feedback had enough black marks to keep looking. I went CCS, and am very pleased.
Crankcase Services, 14700 W Shell Road, Sand Springs, OK, 74063 918-245-6767
Quality Aircraft Accessories for my dual mag, fast turn at no extra charge, OH my core and charged me less.
http://www.qualityaa.com/
It's what I did, and I couldn't be happier.
Rick 90432
