Old 08-19-2008, 02:53 PM
noelf noelf is offline
Default Tip: Hobbs Meter Location
I wanted a Hobbs meter in my RV-6A Tip Up, but did not want to take up any of the scarce panel space for this non-flight critical (my opinion, and I can't ever recall looking at a Hobbs meter in flight) item. Also, I did not want the Hobbs meter in the engine compartment, firewall forward, environment.
I decided to mount the Hobbs meter to the sub-panel that is 6 inches or so behind (forward??) of the instrument panel. This allows me to check the "oil pressure" time only while on the ground and with the tip-up canopy in the up /open position.
Hope this helps...
Old 08-20-2008, 08:35 AM
Vern's Avatar
Vern Vern is offline
Default Hobbs meter
For the same reason I mounted mine behind the pax on the baggage firewall upper area. I can turn and see it if needed but it does not take space in my 6A slider.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
