Welcome to the other Air Force.
As you go through this site, you will learn a lot and find out there are a lot of choices to make as you move forward.
There are very few bad choices you can make and the best part is if you do make a bad selection, you can change it.
A number of people go with wood props on their airplanes because they are both lighter and smoother than metal. The current favorite is from
Craig Catto. (They have a long lead time but then so do you, at this point.)
As you build, you will have to decide between budget, function, weight, and desire when selecting options. You will soon learn there is no clear cut answer to any of the questions you are going to ask. Just build the plane you want and not the one others want you to build.
