Old 08-17-2008, 03:33 PM
gbrasch gbrasch is offline
Guest
Default RV BUILDERS ARE CHEAP (?) !
Check out my latest posts on Jeff Point's thread found here:
http://www.vansairforce.com/communit...d=1#post248575
...to see if you are one of them.
Old 08-17-2008, 04:21 PM
mike63 mike63 is offline
Default CHEAP!
BACK TO YOU.
Mike Spoon
N8391 reserved
RV7 empennage
VAF#1639
Old 08-17-2008, 04:24 PM
Guest
Default Mike, Your On.......
...........see my post on the other thread.
Old 08-17-2008, 05:01 PM
RV6_flyer's Avatar
If it were me, I would change RV to "Most Airplane" builders,"owners, and pilots" are cheap.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-17-2008, 08:11 PM
osxuser's Avatar
osxuser osxuser is offline
YEAH RV BUILDERS ARE CHEAP! Try making a living working on experimentals! The people who BUY RV's are MUCH easier to work with than the people who have built them. I've noticed that builders are MUCH worse than the average aircraft owner. I've probably done 15-20 condition inspections in the last 2-3 years, and work as a A&P for the last 6...
RV4 wing in Jig @ KPOC
RV7 emp built
Old 08-17-2008, 08:47 PM
Default cheap?
the cutomer does not decide the value of your work by themselves.you and the competition decide what is worth. I charge $85 to $105 just to tell you what it will cost to repair your airconditioner,you get paid for knowing what screw to turn not for turnig the screw. why repair 10 at $10 when you can repair one for $100. you will work less and make the same or more. life is short and time is all you have. spend it wisely there are no refunds.
Mike Spoon
N8391 reserved
RV7 empennage
VAF#1639
Old 08-17-2008, 09:21 PM
the_other_dougreeves the_other_dougreeves is offline
Absolutely. The bank account can be measured with great accuracy, but you never know how much time you have left. As the saying goes, plan for tomorrow, live for today.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
