Old 08-17-2008, 01:18 PM
weriderv8a weriderv8a is offline
Default Sika-Flex
I'm getting ready to make "The Big Cut" and start on my canopy. I'm still debating about Sika-Flex or the standard Van's method. I have read a lot of various inquires and opinions on this link but is there a link with instructions on the procedures required for bonding with Sika-Flex? I'm doing a RV-8 slider.
Tom Davies RV-8A
firewall forward
N60TD (reserved)
Citrus Heights CA
Old 08-17-2008, 01:48 PM
tonyjohnson tonyjohnson is offline
Default lots of info
Tom,
If you do a search here on the forums you will find lots of information about the sika flex method. Mickey Coggins has a website that is very helpful as well.
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 08-17-2008, 02:42 PM
C-J C-J is offline
Default Sika Flex
I just finished and I my mind it is the only way to go. It seems so much stronger, like an integral unit with the frame when you are done. All the RV at our air park have crack at the pops somewhere. Follow the instruction from any of the pioneers, you must have at least a 1/8 gap and use big fillets. Here is my site, look under canopy
www.mykitlog.com/carlbell
Old 08-17-2008, 03:34 PM
flion's Avatar
flion flion is offline
I Sika'd mine, liked it and think I could do a better job easily the second time. Here's the best link I've found; it includes links to buy the stuff and info sheets. The only advice I'd give is do a practice piece with some scrap aluminum and plexi; you can do that early in the process while you are still trimming and fitting. Then you'll have a better idea of how the application will go. Like fiberglas work, patience really pays off here.
EAA Technical Counselor #5357
Old 08-17-2008, 04:35 PM
Hwood Hwood is offline
Default Do It
No doubt....do it!
Hwood
N469SH / "Crazy Woman" (sold)
Working on Another -8
Exempt but paid
