Old 08-17-2008, 07:26 AM
Geico266's Avatar
Geico266 Geico266 is offline
Default Advancing Slick Mags Settings?
As my mind wonders about timing an engine, I asked an A&P friend; "If 25 BTDC is optimal when running 100LL, why not time it at 28-30 BTDC when running mogas? Would this help get more power out of the engine if advancing the timing is a good thing with EI?"
This is on my 0-235 -3.
I guess I could always try it and report the results, but I thought I would ask the much more knowledgeable VAF crew first.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-17-2008, 09:22 AM
lluciani's Avatar
lluciani lluciani is offline
Larry, I recommend that you do not try this. To prevent detonation, lower octane fuel may require that timing be retarded - not advanced.
I have a Superior XP-360. The manual requires timing to be set at 25 deg BTDC for 100LL. It recommends 22 deg BTDC for 91 octane auto fuel.
Luis Luciani
Old 08-17-2008, 10:26 AM
asav8tor asav8tor is offline
Luis is spot on.
Do not do it.
Old 08-17-2008, 11:07 AM
osxuser's Avatar
osxuser osxuser is offline
100LL burns slower, therefore then spark advance being more with Avgas.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 08-17-2008, 02:48 PM
Geico266's Avatar
Ah! This advice makes sense. I guess my mind wandering can be a dangerous thing!
Thanks guys!
