Hi ya'll,
How about a thread for builders who have completed their RV to write about things they would have done differently? Perhaps this would help our brothers and sisters who are still building avoid our mistakes.
I'll start, on my RV-7A (QB, so I can't take too much credit...):
* I installed passenger toe brakes. Oops - not much benefit and just adds weight. ****, I hardly have to use the pilot's side brakes even with the castering nosewheel. For a taildragger the passenger brakes may have some value.
* Drill a tube inflation hole in the nose pant (or use nutplates on the attach bracket) before putting the pants on the plane. I figured I'd fly it for a while to see how annoying I found putting the nose on blocks just to add air - suffice it to say, it's damned annoying.
* If you have an O-360 and a Hartzell prop (like me) - perhaps put the strobe supply and ELT forward of the baggage wall. My weight and balance is pretty good, but with two 170lbers, the baggage is limited to 80 lbs due to CG constraints.
* For the wingtip antennas, consider using RG-58 rather than RG-400 coax. The loss isn't such a big deal (assuming we're talking com 2 and VOR) and it weighs less.
* I left out map pockets, figuring I'd see if I needed them. Um - I now see that I need them.
Things I'm happy with:
* Parking brake
* Non av strobe power supply
* Using prefab multistrand 22 awg bundles for the auto pilot wiring. Much smaller than rolling my own.
* A short length of flexible PVC as wiring conduit under the baggage floor.
* The whimpy Van's (manual or electric) spring system for roll trim works just fine.
* No interior other than carpet on the floor and nice seats.
Kevin
