Originally Posted by C-J
For those that have gone before me, I could use some Sika Flex Expert
advice:
1. I would like to go back and fill the spacer holes and pretty up the
fillet around the frame. Do I just use the Sika cleaner to re-soften the
primer and Sika for the finishing layer?
2. Will the new Sika stick to the first layer well enough. Can I sand the
Sika in the high spots before the finishing layer.
When I did mine I called Sika USA tech support regarding a second application of the adhesive. I used a small/narrow bead initially and went over all the joints a second time (after the spacers came out) to lay down a nice smooth bead for cosmetic purposes and maybe a little more joint strength. The recommendation from Sika was to clean with the cleaner and then apply the glue.
The concern with the second application of the glue is that you want to get the second layer on ASAP (within 48-72 hours the guy said) so that the 2 layers of glue are able to bond together better. That said, I suspect that a really good adhesion of the second layer to the first is not all that important as the first layer by itself is probably strong enough and the second layer is mainly cosmetic.
