Old 08-11-2008, 11:48 PM
szicree szicree is offline
Question Baffle Seal Overlap Dimension?
This is for those of you with flying RV's. How far should the lower inlet seal overlap the forward aluminum ramp of the baffle? My baffle drawings show a gap between the cowl and ramp of 3/8 inch, but don't say how much of the rubber should be lying on the metal ramp. What has worked well?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 08-12-2008, 05:08 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default overlap
Looks like about an inch or so is the norm. Thats where mine is. Keep checking it for chafing after you start flying, as you may find it takes a bit of trimming on the outer edges to minimize this.
HTH...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 08-12-2008, 05:23 AM
pierre smith's Avatar
Default What Chris said.......
.....and one other tip. When you start adding the rubber seal to the baffles, if you'll cut the roll of rubber across its narrow dimension, the seals will already have a curve that you install pointing inwards. This way you don't need to "train" them.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
