Old 08-11-2008, 04:29 PM
NYTOM NYTOM is offline
Question Rain Drains
Anybody out there have any tips on drilling drain holes for any rain water or other moisture that collects in the plane. I'm finally completing my first wing and realized there's no provisions for any drain holes. My old Ercoupe had drain holes everywhere and it was amazing how much water passed through that thing. I figure it's pretty much common sense where the waters going to collect but what size holes are you guys drilling. I might have to tie-down outside for a while waiting for a hanger rental so it's kind of important .
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 08-11-2008, 04:44 PM
AlexPeterson's Avatar
Default Great question
Tom, I don't recall putting any in the wings, it seems like those are ok. The various corner reliefs built into the ribs, etc., make for allowing water to drain. It is the fuselage and the rudder bottom that need drain holes for sure. Once the plane is complete, you can spray water on the belly, and based upon where it collects, you will know where to drill the hole(s). Seems like I had two, somewhere in the vicinity of the aft wing spar. The 7's and 9's would be quite different.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 08-11-2008, 08:25 PM
Smile Thanks for the good advice
After I read your response I went down and stared at my half skinned wing and imagined I was a splash of water trying to get out. Your absolutely right Alex, it doesn't seem like it's going to be a problem.
Hopefully I'll get to try your idea on my fuselage within the year.
Thanks for your help Alex.
PS Nice web site you have there.
Tom Norwood
TMX-O360. Phase 1
Old 08-12-2008, 05:25 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Out of interest - how big a diameter were the holes?
Jim Sharkey
RV6 - Details!
Old 08-12-2008, 05:29 AM
Vern's Avatar
Vern Vern is offline
Default Water Drains
You should consider a 1/8" drain hole in the airbox bottom, rudder bottom,and in front of each fuselage former. I've seen aircraft with 4-6" deep water in the rear fuselage (not RV's).
Most RV's are pampered and live in nice hangars, but being tied down on x-country or a heavy rain during flight could change things.
I saw a famous RV-6 abort takeoff and almost drown out the engine because of no airbox drain after a plane wash.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 08-12-2008, 06:03 AM
Tom - thanks.
Jim Sharkey
RV6 - Details!
Don't recall exactly - maybe 1/4" since that is the smallest my unibit can make.
Alex Peterson
KADC, Wadena, MN
Old 08-12-2008, 06:53 AM
noelf noelf is offline
I'm building a -6A and installed drain holes on the aft side of each bulkhead. Taildraggers may want these holes on the front side of the bulkheads. The hole size was smaller than a #40 drill bit...I think.
I positioned the drain holes on the center line (while the a/c was in the jig) so that at some future date, I could relocate the center line with little effort to validate any asymmetric issues/ concerns/screw-ups that I might come up with.
Old 08-12-2008, 07:34 AM
Mel's Avatar
Mel Mel is offline
I would recommend that the holes be about 3/16" as a smaller hole can easily be clogged by trash. The drain holes in my -6 are 3/16".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-12-2008, 12:32 PM
jsharkey's Avatar
That sounds about right Mel,
Too small and even surface tension might stop all the water draining.
Where did you place them? Center line?
Jim
Old 08-12-2008, 12:46 PM
Mel's Avatar
Mel Mel is offline
Jim
Centerline just forward of each bulkhead.
